dangol's avatar
dangol
Towing with Toyota Tundra - any input or suggestions?
Hi there,
One more newbie post for now.
I have read the FAQs on Towing, and done a fair amount of research. I am planning to tow a bumper hitch travel trailer with my '13 Toyota Tundra. Along for the ride will be my wife and two teen boys.
I have just started to search for a trailer in earnest. So if anyone has any specific models, or brands that they recommend for just starting with with the classic "family of four" I would love to hear it.
We are planning 4-5 day outings in loops. Got any thing to share, I would be much obliged.
Thanks Dan Goldberg
  • As stated above, with a 1/2 ton you are limited with your weights, but that is no reason why you should not be able to find a really nice camper that will serve you and your family for a while. I say "a while" because chances are, in 3 years or less, you'll probably be looking for a new truck and a new camper combination. A truck that is heavier and a camper that is bigger. First time buyers learn by their first purchase. It probably does not matter what you purchase, you'll be ready to trade in a few years. There's nothing wrong with that.
    With that said, there are many brands of light weight trailers that would accommodate a family of 4. As with any camper, we all have to determine how much camping equipment and supplies we need for our creature comforts.
    Don't necessarily limit yourself to just a hard sided travel trailer. Pop-up's Hybrids (hard sided campers with fold out tent ends), egg shaped style uni-body campers like the Scamp, or tear drop styled campers are possibilities also. Don't completely skip over the idea of getting a pop-up, or an A-liner, or even a Teardrop style camper. All of these are single axle trailers that would work quite well with your current vehicle.
    You have millions of options available to you. And unfortunately, only you can finally decide what will work best for you. We can give our opinions, but at the end, the decision has to be yours.
    For what it's worth, we wanted to get off the ground after tent camping for years and years. My tow vehicle was a Chevy Mini Van. It did have a V-8 engine, but the transmission was definitely not suited for towing. After talking to a couple dealers we faced the reality a pop-up camper could be towed by our van. When we finally found the pop-up we fell in love with, even it was too heavy for the mini van. Thanks goodness we had an honest dealer that told us the way it was! We ended up getting a smaller pop-up that served us for 6 years. That same mini van towed that pop-up all over this country with a family of 4 and pets too. We thought we were "king rat" with at outfit! Happy as 2 bed bugs against a warm body! We had some great times with that pop-up.
    We traded the van first. After owing it for 10 years, it started having problems that were beginning to mount into more $$$ than we wanted to invest ... like windows that quit working, air conditioner that didn't cool any more, stuff like that. Transmission and engine were wonderful. We traded it for a Suburban under the original Cash for Clunkers program. From there, it was a bigger tow vehicle, then a bigger trailer, then a bigger tow vehicle and then a bigger trailer. So it went back and forth.
    So what I'm saying is, bottom line, if you look at almost any single axle campers out there, they will probably work quite well for your tow vehicle and family. Just keep in mind, in about 3 years ... if you rally love this life-style, you'll begin to think, "trade!" It just happens, so plan on it some day.
    Good luck in your search. Keep us posted on your progress.
  • Our Tundra pulls our Minnie without a problem. The 2451BHS model only has a dry weight of 60 more lbs. Winnebago Minnie
    I pulled our old Sunline (30', approx. 75000 lbs.) just a couple of times with our Tundra and would not wanted to do it all the time as the load just felt too heavy and power lacking for any mountain driving. My rig weighs 6200 lbs. minus food, drink and any water in the fresh water tank. We've already done trips from OH to Florida and New Orleans and it has been an easy tow! My average gas mileage is between 9 and 9.5 mpg. with travels speeds maxing at 65 for the most part, but I have done some stretches at 70.
    IMHO, bottom line is don't plan to tow more than 6500 lbs. considering you'll have four people in the truck and probably some stuff in the truck bed.
  • #1 You are going to get a LOT of derogatory responses here because its a half ton (grocery getter) and because its a "foreign made" (see my signature) truck.
    #2 Your biggest issue will be available payload when loaded up with your family and whatever you load in your truck. Go weigh your truck with the kids and some gear in the truck. Once you know your loaded weight you can determine your available payload. Once you know your available payload, you will have a better idea what you can haul.
    I have a 2010 doublecab with about 1000 lbs of available payload after the wife, toddler and newborn are loaded. Figure 75 lbs for the WDH, I have just over 900 lbs for tongue weight and gear.
    I load everything in the trailer (have 2500 lbs available payload in the new trailer) and expect to have around 800 lbs tongue weight LOADED with the trailer.
    If you can keep the numbers right, the Tundra is a GREAT vehicle to tow with. I have factory E rated tires and added the TRD sway bar. My truck is solid when towing, I don't get pushed or pulled around when towing. Braking has always been solid (east coast towing, I won't get to the Rockies with this truck or trailer) and handling is great.
