Npdchief07's avatar
Npdchief07
towing without a weight distribution
I have a 2019 Wildwood X-lite 30ft travel trailer. I am towing with a F350. I currently use an EAZ lift set up with weight distribution and sway control. One of the weight distribution bars won't stay in. It keeps coming out of the (not sure what you would call it) hitch. It appears that the retaining clip is bad. I know it can be replaced and is a cheap part but I am not handy.
Is it okay to tow my trailer (approx. 5500 lbs) without the weight distribution or sway control?
  • Put it in and if it's not sagging in the middle, you will generally be ok as your truck seems adequate.
    And check the handling too.
