Gdetrailer
Dec 01, 2018Explorer III
4x4crazy wrote:
I'm looking at new jayco jay feather trailers and in specific the 24rlsw model. Weight is about 5200lbs dry 7000lbs gross. I'd be pulling it with my 2017 f250 super duty with the diesel. Debating if I should even use load leveling or sway control. Ford says there's no need. My truck also has a built in sway control. Ive read of people towing much more without load leveling hitches with this truck and it's almost thr same weight as my boat. ..im more concerned if not having a weight distribution hitch will be a big issue if I ever go sell it. Looking for opinions
You are pretty much in the same place my setup is, on the bubble to need or not to need.
My TT is 26ft long, weighs 5400 empty and loaded about 6300 with a loaded tongue weight of 875-900 lbs..
Have towed this same trailer with a 2003 F250 super cab 4x2, 2006 F250 super cab 4x2, and current 2013 F250 Super cab 4x2.
Never used any WD with any of the above vehicles and the combination tows great. I have also more than once made emergency stops from 70 MPH to avoid hitting deer on the highway without any feeling of losing control..
F250 has PLENTY of up front weight in the engine, transmission and in your case (I am assuming that you have 4x4)the front 4x4 axle and most likely to not need much if any "correction" in weight loss from the front axle.
I would recommend trying without first, if the tow feels solid and ride is OK you most likely will be fine.
However, keep in mind, my 4x2 sits CONSIDERABLY LOWER in stance than a 4x4. 4x4 suspension raises the vehicle body 11 inches!!! YES, ELEVEN INCHES, I HAVE measured this difference!!
That extra height you have raises the vehicles center of gravity (COG) considerably which may lead to more body sway than what I have..
The ONLY thing I think WD will do for you is perhaps reduce a bit of the "purpoising" of the front end (I am used to that since I came from a family that had slide in TCs and boy can those "porpoise").. And perhaps help compensate for the additional body height that you have..
