intheburbs
Oct 28, 2015Explorer
Campfire Time wrote:intheburbs wrote:
No issues. Trailer was stable, nor more push/pull than my trailer with WDH/Sway control.
How did the steering feel? Your front end seems a bit high. GM spec is to bring it back down to stock height.
Steering felt fine. Based off my weigh slip, the trailer reduced my front axle weight from 3700 to 3200 lbs.
But seeing as how its empty front axle weight is 3300 lbs, I wouldn't expect much of a difference in front axle height or steering feel.
The trailer added 1600 lbs to the rear axle, and removed 500 lbs from the front axle. So the front end looking high is due more to the rear squatting than the front rising.
44,068 PostsLatest Activity: Jun 09, 2026
