allen8106
Oct 28, 2015Explorer
Part of the issue with your post is that I think you are confusing two different components. You mention spring arms (sway bars) in the same sentence implying they are one and the same. They are not. The spring bars as you call them are the weight distribution bars that takes weight off the back axle of the tow vehicle and moves to the front axle. The sway bars are different bars that minimize the back and forth sway of the trailer when towing. I would not tow without the weight distribution bars unless the you are certain it won't create steering issues, meaning minimal weight is moved front to rear without them. I would certainly consider not installing the sway bars for a cross town trip, just make sure you keep your speed down as to much speed will likely initiate sway that could lead to a disaster you don't want.
44,068 PostsLatest Activity: Jun 09, 2026
