aftermath
Oct 28, 2015Explorer III
allen8106 wrote:
Part of the issue with your post is that I think you are confusing two different components. You mention spring arms (sway bars) in the same sentence implying they are one and the same. They are not. The spring bars as you call them are the weight distribution bars that takes weight off the back axle of the tow vehicle and moves to the front axle. The sway bars are different bars that minimize the back and forth sway of the trailer when towing. I would not tow without the weight distribution bars unless the you are certain it won't create steering issues, meaning minimal weight is moved front to rear without them. I would certainly consider not installing the sway bars for a cross town trip, just make sure you keep your speed down as to much speed will likely initiate sway that could lead to a disaster you don't want.
Oh, but they are the same on an E2 hitch. Just like the Equalizer brand, the bars serve both purposes. Once you have engaged the weight distribution, you have also engaged the anti-sway mechanism at the same time. More advanced hitches do not rely on an add on friction sway device.
44,068 PostsLatest Activity: Jun 09, 2026
