PAThwacker
Oct 28, 2015Explorer
More talk about the end of the k2500 suburban and why you can not go nuts towing stick and tin 30 foot 8500lb plus campers sans wdh or with bars. The true beast burbs are the 2001 to 2006 8.1 big block 4l80 and 4.10 rear. You could tow 10,000lb plus campers. Slap v5 monster hitches on them and be happier than a pig in ****.
2007 to 2013. 6.0 4l80 and later 6sp models. 4.10 rear and the largest trailer could be 7500lbs loaded to keep the tongue weight below 1000lbs
What a joke and matches the same capacity max in the half ton. Long gone was 10 mpg 3/4 ton burb in the camper/boat industry
Now you only can get a half ton burb and I'll let others chime in on the values of loading every seat in a half ton and have zero payload to tow anything.
44,068 PostsLatest Activity: Jun 09, 2026
