Called Method, my wheels are rated at 3600 lbs. I can stay under that weight. Just seems that being able to run 80psi cold will help sidewall compression significantly. The guy at method did mention the HD wheels with that higher rating, doubt I really need those.
My 2012 seems to have very soft rear springs. My buddies 2011 f350 has a much more rigid rear suspension.
Would it be advisable to just get a f350 spring set? The stableloads look pretty slick. Can you stack those with the overload springs? Being that the f350 has that extra upper spring I'd like to match that. Much prefer a stiffer ride.
I appreciate the well thought out input.
