bikendan
Jan 08, 2020Explorer
Waynrdude wrote:
Hello, would you still have your 225 RBS Shadow Cruiser? If you do I have a friendly request. I had a blow out and the tire destroyed the wiring that goes to the slide, both 12v for light and 110v for receptacles. I have the slide end of the wiring under the dinette, no problem there. The problem is where the wires go into the "basement". There are two wire ties on the outside bottom of the slide but I can not see where the wires go for power. Is there a "curly" wire that retracts? With the room extended a photograph would truly help where to start digging for the wire. I would like to thank you in advance if you could help. The manufacture is useless, they won't even answer an email. Wayne
Since this thread is nearly 7 years old and the OP hasn't posted for a very long time, I think you're better off sending them a PM.
44,068 PostsLatest Activity: Jun 17, 2026
