Yosemite_Sam1's avatar
Oct 03, 2019
Toyota Highlander and 26' Trailer
I camped side by side with a camper with this set up and got curious as this seems to be a over-matched and a dangerous set up.
Checked my numbers on Google as Highland I recall at most is rated for 5,000 lbs and trailer must be over 5,000lbs or only slightly below dry (a bigger model than my Coleman).
He explained that Toyota towing rating has some 20% allowance -- so technically his towing vehicle's actually 6,000 lbs. capability.
And he said, his trailer had tandem tires each side, so it's a lighter pull than single tire trailer because the weight is resting on the tires -- not the front of the trailer on the hitch.
It's seems logical and can't argue against since he said he is (was?) a Toyota mechanical engineer.
Well, that put me on my spot -- I'm just a pedestrian and a failure numbers game even with my math-oriented family.
Any thoughts -- or contrary opinion from another engineer?
