- GulfcoastExplorerMy Tundra towing experience by request.... it's not for me.
I won't tow any trailer over 5000# with a half-ton truck. - camp-n-familyExplorer
Gulfcoast wrote:
I sold my Tundra and got a Cummins Diesel... what a huge difference in towing power in the mountains.
You could say that for any gas vs diesel. No comparison. You'd also be comparing a 1/2 ton to a 3/4 ton or 1 ton. Not sure how that is supposed to help the OP? How about including your Tundra towing experience. Not everybody needs/wants a HD diesel truck. - GulfcoastExplorerI sold my Tundra and got a Cummins Diesel... what a huge difference in towing power in the mountains.
- trailer_newbeExplorer IIISee below. 2008 CrewMax
- webwranglerExplorerI'm towing the 4,000 lb. Rockwood in my sig, and I really really like the Tundra towing this trailer. I live at over 6,000 feet elevation, and I go over high mountain passes on many of my trips. The Tundra does great on up- and down-grades.
I'm looking at newer trailers, and I wouldn't hesitate to get something up to 7,000 lbs GVW.
I lusted after a diesel for a few years, but I'm over it. There are lots of threads here on diesel vs. gas, and I've watched them a lot. The Tundra is the only truck for me, but I don't need or want a big, heavy trailer. YMMV. - spoon059Explorer IIShouldn't this be in Tow Vehicles...?
I had a 2010 Tundra Rock Warrior with the 5.7 and factory E rated tires. Towed a 22' 6500 lbs camper and it was great. Baby #2 came and we upgraded to a 31' 9500 lbs trailer. With tongue weight and associated camping gear in the bed we were over payload, so we traded for a used Ram.
The 5.7 is a great engine, always had plenty of power. The transmission was solid and awesome for towing. It had the "sport shift" mode that allowed me to easily downshift to control speeds coming down a mountain. Fuel mileage was around 10 with the 22' trailer, around 7-8 with the 31' trailer.
As long as you don't exceed (or only slightly exceed) your payload rating you have a great tow vehicle. I loved my Tundra. Make sure to do your homework and know your weights, or else it will be an expensive mistake to try to fix. - camp-n-familyExplorerThe biggest complaint is usually that it is thirsty and has a small fuel tank. The tank issue was resolved with an optional 38gal tank. The drivetrain hasn’t changed since it was introduced in 2007 and it doesn’t have some of the fuel saving measures other manufacturers offer so it can be a little thirsty but it is pretty much bulletproof.
- T18skyguyExplorerI use to own a Tundra. It was a great truck and a good puller if you stay within it's limits. It's a half ton, so you can't just drop any fiver on the bed, but can pull plenty of trailers. I sold it and got a 1 ton Duramax. The Tundra's a great truck, but my Chevy Duramax weighs almost twice what the Tundra weighed. The Tundra is just not in the league with the big boys, but if it serves your purpose you can't do better.
- samsontdogExplorerMy son tows a 30 ft TT, 7,800 pds with a 2014 Tundra. He says it tows the same Tt better than the 2007 Ram diesel that he had. The diesel got much better fuel mileage than the Tundra. He would buy another Tundra as long as he stayed under 8,000 pounds towing
- APTExplorerStick to near 6k dry. Get the 4.30 gearing. Performance will be good as well as stability and comfort for driver and passengers. What's the biggest fuel tank? 8mpg * 20 gallons isn't far.
44,030 PostsLatest Activity: Feb 04, 2025
