MNRon
May 22, 2015Explorer
Running tires results in some flex causing an increase in temperature. Sun will also increase the temp. Although more flex will result in some more heat, I think it's almost impossible for *low* pressure to cause so much heat that it turns into high pressure.
My rear truck tires are 80psi cold, trailer 95psi cold. I've set my TPMS alarms 20psi above that. If it hits that I should look to see if I have a brake dragging or a bearing hot. As long as it's normal pressure increase due to driving and sun I'm not concerned. Tire manufacturers say set them cold and then run for the day.
Last winter we left MN at around 10deg and drove to TX, one day the ambient temp rise was about 40-50degs. TPMS didn't alarm, I did let a couple pounds air out before starting out the next day though since we'd be in warmer temps for a month.
Too low pressure is THE reason for TPMS. The temp indicator is a nice to have which *may* help catch a dragging brake or bad bearing, NOT looking for normal tire temp rise.
44,066 PostsLatest Activity: Jul 25, 2018
