BurbMan's avatar
BurbMan
Explorer III
May 22, 2015
TPMS Alert: Tire Pressure Too High?
Loaded up last week in Louisville, ambient temps in the 70's and headed for FL. The LT225/75-16E tires on the TT set to 75 psi.
Down I-65 through AL with ambient temps in the 90's...pavement so hot I couldn't go barefoot.
Exit I-65 and down US 31 headed for the FL panhandle and the trailer TPMS alarm goes off...for high pressure in the RR trailer tire at 89 psi. RF was reading 87 and both left side tires were at 85. I stopped and bled off a few psi from both right side tires and also checked the rears on the truck.....80 psi cold was now a whopping 97 psi!! I brought them down to 90. I don't have TPMS on the truck tires.
Trailer tire temps were running in the 125*F range, not especially hot.
Anyone else ever experience this? Traveling from a cool area to a warm area with climbing tire pressures? I bought the TPMS to warn me of low pressures that could lead to a blowout, but never expected a high pressure alarm.
  • I forget the tolerance mine have but yes mine too monitor for high pressure. I think it is about 10 lbs. I actually had to calibrate mine when installed.
