Got a quick question which I believe I already know the answer to but some of you have more experience with TPO roofs because you have them on your camper. Went to look at the Grand Design 2150 yes...
I believe this particular trailer was poorly assembled. I saw sloppy chaulking,the under belly was sagging, the spray foam on the under belly was waaaay over done and not cleaned up, saw 6-7 roof trust that were protruding.
I have a KZ Sportsman which is an entry level camper that's finished better than that particular trailer.
The 2 I saw at the Nashville show were a much "cleaner" assembly. Did not get to look at the roof at the show.
