time2roll
Aug 29, 2021Nomad
ognend wrote:time2roll wrote:
I agree with Grit. Will depend on the combo and how it tows without. Also read the complete towing section of the owners' manual as there could be more details than the marketing brochure. Some truck hitches want the weight distribution etc. to go over 5,000 pounds trailer weight. Plenty of larger trailers tow just fine with just a pintle hook.
Give it a go and post the results.
I've been towing this trailer since 2007 with 4 different trucks (1/2 ton, 2 3/4 ton diesels and now a 1-ton DRW cab/chassis) - I always used the same adjustable WD/sway-bar hitch since the trailer has been the same trailer since 2007. I was just hoping to see if I can do without the anti-sway bar on the trailer/hitch and maybe without the weight distribution as well. The trailer has a GVWR of 7,000lbs and my current truck is 8800lbs. I read my towing section of the truck manual and I understand about weight distribution in trailer and need to have 10-15% of trailer weight on the hitch.
I don't think anyone can definitively say if it will work well or not with your particular combination.
If you sense more sway or do not like the control effort by the vehicle it will be very simple to put the old equipment back on.
Don't head into a gusty cross wind at 70+ on the first try.
