ognend
Aug 30, 2021Explorer II
Sjm9911 wrote:valhalla360 wrote:
It will work but not as well as a properly set up trailer with a good hitch weight and a WDH with sway control.
One problem is if it is activated a lot, you will wear out brakes and burn more fuel...so better than losing control but not a good plan for every day towing.
I have pondered the same. Just set the wdh with a tad bit of weight and make use of the sway controll. I upgraded to a 2500, i dont need a wdh hitch or sway controll either. But i still ise it because, i have it , and it can help. Tbh, this last trip it probably saved my ass. Going over the Delaware bridge, at like 55 mph, a large garbage can type construction cone was shot in front of me. I swerved a bit, not much as there was cars in both lanes on my side. I hot it with the truck on the front left. It cam back at me and hit the TT on the front left. If i dint have the equilizer i think i may not have controlled the sway from the impact. Trailer, lucky had minor damage, ripped the bolts of the bottom of the dimond plate, and took out the electric break wires. Use the hitch. Its not just about minimums. It can save you a wreck. And maybe your life. While this dosen't happen often it can happen. And i dont know for sure that the wdh/sway saved me. But i will say i think it did.
Thanks for relaying your experience - I am one of those people who is always checking and double checking and understanding weight limits,distribution and erring on side of caution. This thread was more to see if TCS and Stabilitrak made the hardware in the back obsolete (I guess not!). One thing I dislike is the WD bars on my hitch, since I got this new flatbed DRW cab/chassis, in full-radius turns the back of the flatbed is low enough to hit the WD bar and hence limit my turning radius. This is is what really started the ball rolling on getting rid of WD and sway bar... ;)
