Grit_dog
Aug 31, 2021Trailblazer
ognend wrote:
Thanks. I am a bit puzzled as to how to approach this. Right now I have the new '21 Chevy DRW cab/chassis truck. I am waiting on delivery of a Palomino HS-2902 Max truck camper which will be around 4200 lbs wet. This leaves me about a 1000-1100 lbs for the bumper pull hitch for my about 6500-6800 lbs horse trailer. I guess I will know once I have the whole combo set up. My guess is that the truck camper will lower the back of the truck enough for the WD to be necessary with the bumper pull hitch. Not excluding the possibility of needing a set of Timbrens or SuperSprings to bring the truck back to level. After it is at level, I will have to determine whether I will need a WD and anti-sway bar. So many variables....
Whether you need sway control is not predicated at all on whether a camper is on the truck. WD, yes, maybe, if you need to pull weight off the truck's rear axle and don't want to add to the suspension.
