valhalla360 wrote:
I'd have to dig it up but unless your state makes an exception to the uniform vehicle code, you are required to hold a steady speed when someone is merging in.
As I've said in previous posts, if you can move to the left, that's fine and probably better (though not a requirment) BUT that wasn't available to the OP because there was a semi in that lane and while it's nice to say you would never get in that position, sooner or later it will happen.
Also, if you are going to hang in the middle lane, make sure you are keeping up with the faster traffic. Yeah, you will burn some extra gas but if you run a 55 in the middle lane and they want to go 70 you are creating a new safety problem.
You can dig if you want, but I do not know of any rule that "requires" you to maintain a speed in this case. The vehicle that is already on the freeway has the right of way over the vehicle trying to get onto the freeway, that much is true. But I defy any officer or anyone else to cite someone who slows down to allow a person to merge ahead of them. Stubbornly keeping a speed when it is all too obvious that someone will be hitting you can actually end up having you at least partially at fault for an accident for failing to take available evasive action.
You may be confusing a case where someone is passing you on the left (on a smaller, 2 lane type of road where you go onto the wrong side of the road to pass). In that case you are required to maintain your speed (not speed up) so that the passing vehicle can get back onto the correct side of the road. Even then, there is no prohibition as far as slowing down and letting that vehicle in sooner.
I agree with the rest of your post. Obviously, if you can move over and allow a vehicle to merge from an on-ramp that works well, but it is just as valid to slow down and let them get ahead of you if it looks "doable". It is a bad idea to slam on the brakes or brake sharply to let the vehicle ahead (unless you are avoiding a collision) but since all of us in this thread are paying attention we can usually anticipate merging traffic fairly well and respond accordingly.
I only travel in the lane to the left of the far right lane when in the city and basically all lanes are traveling the same speed. I am allowed to be in that lane as long as I follow the rule of slower traffic keeping right. In the boonies, I only go into that lane (if there is slow traffic in the far right lane). Most of the time, I am the slow traffic.
PS The Uniform Traffic Code is not law. It is privately written code that serves as a guideline for state vehicle codes. The vehicle code of the state you are driving in is the definitive law. There is really no Federal Vehicle Code, but most states are consistent with the Uniform Vehicle Code guidelines.
