- theoldwizard1Explorer II
donn0128 wrote:
Check the sidewall for country of origin. That will answer your question
I don't think ANY trailer tires (ST) are made in the US ! If you want US made, you will have to go with Light Truck (LT) tires.
Make sure they have the same load capacity (on the sidewall). - coolbreeze01ExplorerWeight, tire size, load rating and care matter.
- CoolermanExplorerI have the Trailer Kings on my 2016 Sonic Venture 170VBH. ST205/75R14 Load Range C Have about 8000 miles on them, all highway at 60-70mph. Mostly around 62, as that is the speed my Nissan Xterra tow vehicle wants to go. ;)
The tires are rated at 65mph. Zero issues with them. Still look new! I will buy them again if they continue to do as well.
Kept at 50 PSI, and monitored every time I stop for temp differences using an infrared heat gun. At highway speed they run about 100-114 depending on outside temp. - skilesExplorerWe had a set of 4 Trailer King's (E rated) installed in February of this year. I'd say we have about 1000 miles on them and have had no issues. So far, so good...
- rbpruExplorer IIMy TT had 4 year old tires on it when I bought it. They were like new with no sun damage. The were the typical ST 205 load rated C made in China.
Three years and 15,000 mile later I replaced them. I move up to D Rated China bombs so I had some leeway on the tire pressure. Plus they were only $20.00 more per tire over C rated. I have another 10,000 miles on those and so far so good.
I am towing a 7000 lb. gross weight TT at 60 to 65 mph.
I kept the old ones for my other farm wagons.
I asked the local tire dealer for his recommendations on a good D rated 205 TT tire and bought what he suggested. The tire dealer tows a fifth wheel cross country when he vacations. - HannibalExplorerHad a set of E rated 225/75 R15s on our previous 5th wheel. In the year we had them before we traded the 5th wheel for our current TT, we didn't have any trouble with them. I'd estimate 5k~ miles on them.
- camperforlifeExplorerI've got about 12K on Trailer King's. So far so good.
- midnightsadieExplorer IItheres a good answer.might google that tire and see what shows up. good luck.
- AmericalVetteExplorerI bought a set of Trailer King (ST225/75R15) from a local tire shop for a TT I used primarily for hunting. I put about 5000 miles on them, and much of it on dirt/gravel forestry roads. I sold that TT to a friend who uses it for the same thing and under similar conditions. The same tires are still on it and he has not had any problems that I am aware of.
- retired1ExplorerWe put Maxxis on our previous trailer to replace the Carlisle tires that came on it and did NOT have a good experience. They all came apart in one long trip. The question was about Trailer King and if anyone had any first hand knowledge. They came with the trailer. Didn't have a choice.
Thanks
44,068 PostsLatest Activity: Jun 10, 2026
