Gdetrailer
Jun 10, 2013Explorer III
SprinklerMan wrote:
That tire presure may also be a bit light .
If you are talking the tire pressure of the VEHICLE then you are dead wrong. The OP has a F150 which will have as standard equipment P or PASSENGER TIRES. 44 PSI IS the max pressure of those tires.
As far as I am concerned, what the OP is feeling would be pretty much NORMAL when going from a heavier and STIFFER suspension to the softer almost mushy "caddy" suspension of a F150. The OP DOWNGRADED the tow vehicle and can FEEL the difference.
The problem is most folks who have 1/2 ton trucks just don't "get it" since they have never experienced a better platform...
