kaydeejay
Jun 03, 2015Explorer
thomasmnile wrote:What does any of this have to do with 110 volts?kaydeejay wrote:Um, not quite. Go back 1 page. Since I had the truck in for the Takata recall, service writer asked if there was anything else. Told him about the trailer brake issue, and could they check the truck wiring and replace the fuse. They had the truck two days, wasn't done.
When did the 110volt side if your system come up??
Everything we have been talking about re your truck and trailer
Once bitten, twice shy with this dealership. Took it there to run down a problem with the electrical system last September, dash volt meter was showing less than 12 volt output. Had it all day, scanned it they said could find nothing wrong and collected $105 for their 'effort'. Problem persisted, took it to the mechanic in Orlando that regularly services the truck, they found a problem with the cooling fan clutch and replaced it. No voltage output problem since,normal 14.2 v output. Don't pretend to understand that, but I do know the cooling fan now works, I'm not certain it ever has in the last couple of years.
