thomasmnile's avatar
thomasmnile
Trailer Brake or Truck Problem?
2005 Ram 3500 QC, Prodigy P3 brake controller (plug n play to truck harness) 2013 Jayco White Hawk 27DSRL (Dexter Axles/Electric Brakes)
Recently did a quick weekend to St. Augustine. Hooked up trailer doing brake check and manually activate trailer brakes, brake controller says trailer not connected. Checked 7 pin connector, went under trailer checked brake wiring no problems seen. Two 30 amp fuses at trailer positive cable battery connection, checked them, no problem (what are those fuses for anyway? They are on wiring between battery and a junction box of trailer frame, the tongue jack is separately fused). 90 minute trip up the road, flat terrain, good weather, truck brakes have plenty of whoa for truck and trailer so off we went. Got to campground and checked the truck's fuse for the trailer brake cicuit, it was blown. Replaced the fuse, hooked up the this morning and all is good. Brake check, manually activate the trailer brakes, no problem. Had the voltage output on the controller set to 8 volts. Brakes worked fine, typically drawing 5.9 volts when I hit the whoa pedal. Get off I-95 to head home apply the brakes and controller once again says trailer not connected. Haven't checked the fuse on the truck yet, but pretty sure I'm going to find it's blown.
I hope I provided enough info for the mechanical sleuths out there, but I'm at a loss for where to begin. In 3 years, I've had zero issues with the trailer brakes, and am inclined to think the problem is with the @#$%^& truck. The only thing I did to the trailer brakes prior to leaving was adjust them. Any thoughts, suggestions, quick cures? Thanks.
