mdcamping's avatar
mdcamping
Trailer brake problem?
The Jayco 24 RBS I purchased this spring I noticed the back 2 brake drums where super hot and the front 2 drums where not hot at all after doing a trip. Had to wait 1 month for my scheduled service today. Tech said rear brakes were almost frozen, cleaned up brakes and calibrated. After hooking up trailer at the service center which was on a slight down grade I let the truck & trailer roll slowly in neutral. I then put on the manual break to full gain... Nothing... I then got the tech we repeated the test with him pulling the brake away pin.. still nothing... So tomorrow the shop foremen is going to work on the brakes.
So my question is on my past 2 trailers when doing a similar test when I activated the brakes in full manual gain the trailer brakes always locked up or almost locked up. I a missing anything? help.
Also had the bearings repacked.
Mike
  • I do my own brake maintenance because I know that I do it correctly. Some shops hire anyone that thinks he knows what a wrench is.
  • I don,t read where the shop tested your brakes before turning the rig over to you? need new shop. you could have pulled down the high way with no brakes.
