Campteacher's avatar
Campteacher
Trailer brake upgrade question
Hello friends,
As you can probably see based on my other posts, in less than a month I'm picking up my new 2018 Jayco Jay Flight 285 RLS SLX. Its GVWR is 8250 pounds, and I have a 2017 Ram 3500 CTD.
My question is this: is it worthwhile at all to look into a disc brake upgrade? Would that just be wasted money? I will only tow in flat Alberta this summer, but my destinations will change next season.
thanks!
Kevin
  • I think the biggest benefit is emergency stopping power you end up with.
    That is definitely worth something.
  • Yes. I upgraded my Grand Design 313RLTS in part because of a known failure of earlier Lippert brake seals failing, bathing the brakes in grease (not a good thing), but mainly because I wanted to not have to rely on 50's technology to try and stop my 10,000 lb trailer. The difference is night and day. Out the door it cost me $2,800 to do both axles, but the brakes are really great - then can actually stop the truck.
    Well worth the money in my mind.
  • I would basically say waste of money. The engine braking works really well. Besides, 8200 pounds is nothing.
    But on the other hand have you searched late model ram in dash low controller voltage issue?
