WayneAt63044
Oct 11, 2022Explorer II
For a while I had some self-adjusting and some manual adjust brakes. The self-adjusting drums would measure 120 degrees while the manuals were around 90 degrees after a 2 hour run. I since have gone to all manual adjust brakes to keep the temperatures down. You really don't want to adjust them to rub a bit like the self-adjusting always do.
To test bearings & braking I would jack up one wheel at a time and check for just a very slight wobble in the bearing and then pull the emergency brake cable to engage the brakes. Then spin the wheel forward to determine how far it rotates with the magnet energized before the brakes apply. Never got over 1/2 turn before the brake shoes stopped rotation by hand.
No need to have things so tight you get unneeded friction and heat.
44,070 PostsLatest Activity: Jul 21, 2026
