JRscooby
Jan 05, 2022Explorer II
Cummins12V98 wrote:
I would use this.
AMAZON for $15
Copy and paste below.
Hosa D5S-6 CAIG DeoxIT 5% Spray Contact Cleaner, 5 oz.
theoldwizard1 wrote:
DeOxit is better than WD-40. So is FluidFilm.
Think about it for a second. Are any of us sure what the problem is? W D stands for Water Disbursement. I used it often inside distributer caps to start engines after they got wet (Point & Condenser). It will do no harm. Now is there better things for it? Sure. But I bet the OP has a can around, or can pick some up for few bucks. If he uses, the problem goes away, he knows where the issue is. If it comes back, that would be the time to spend for the better stuff, or even better, seal it up so water can't get in.
