subcamper
May 01, 2019Explorer II
I had one at our old house for our 8000lb trailer. I think it was a Power Caster. I got rid of it when we moved out to a rural area and no more "squeezing-through" needed.
If you are on level pavement it should work fine.
Make sure you have control of the trailer brakes. Mine had a connection to trailer connector so a toggle switch on the dolly control panel would activate the brakes. A trailer can build up quite a bit of momentum. Even if the ground looks level, it probably has a little slope. If the trailer is moving and you shut off the dolly, it will push the dolly, even with locked wheels on the dolly.
Also, if you get a 120V model with a power cord (like mine was), watch the cord. It's possible to be so concerned about watching the trailer sides that you run over the cord, pulling it out of the control panel. Yeah, that's what happened to me!
Steve
Steve
