subcamper
Mar 22, 2015Explorer II
Back about 15 years ago,I replaced the sheet vinyl floor in our kitchen. Armstrong had a template kit that consisted of a bunch of paper sheets, tape, and a pen that had a wheel at the end to follow wall/cabinet contours. You would overlap the paper sheets, tape them together where the edges roughly followed wall/cabinet contours, and then use the rolling pen to draw the exact edge needed. The edge draw was 1" inside the actual edge, so you added 1" all around to the border line. This created a full-size template of the area that you placed over the (unrolled) sheet vinyl (on a large floor or outside). You then cut it out and it fit well.
I don't know if the template kit is still sold, but I would recommend it for sheet vinyl as it is pretty hard to cut it around things as you unroll it without ripping it.
Steve
Steve
