yblaw
Feb 02, 2018Explorer
Kayteg1 wrote:
Careful with utility trailer in CA and probably in other states as well.
Having commercial registration on your truck, you should declare max GCWR at registration and display weight sticker on your door, or pillar.
That will also push you via the scales and checking trailer emergency brake systems is red flag for DOT.
RVs are exempt.
That may not be correct. I believe that trucks registered in California that have a curb weight of less than 8,000 lbs., a GVWR of not more than 14,000 lbs., and have a standard pickup bed--are exempt from "weight tags," stopping at scales, etc., so long as the trailer they are towing has a GVWR less than 10,000 lbs, and the combined weight of the trailer and its load is under 10,000 lbs. The OP's anticipated rig of a 4,000 lb. TC on a 2,000 lb. utility trailer should be exempt, so long as his pickup truck has a conventional truck bed. I apologize to Kayteg1 because I'm sure this is the first time he posted erroneous information
44,056 PostsLatest Activity: Jan 12, 2020
