JRscooby
Dec 02, 2019Explorer II
SAR Tracker wrote:
Scrub off the top of the hitch (above where the ball would go in). Should be a size, etc, stamped into the metal. Might be painted over, so a little sandpaper might be needed.
Just ignore this.
Use some penetrating oil, and work the latch open and closed. If you are sure it is open all the way and 1 7/8 will not fit, then might as well replace the coupler.
