Gdetrailer wrote:
May not just be an "Operator error" if the clip "disappears" via a third party "prankster" that happens along when you are away from your vehicle..
Have heard of that happening, fortunately have never had that happen to me.. But I do typically do a quick walk around and check to make sure everything is in it's proper place as it should be when taking rest stops and such before I get back on the road..
Happened to me about 5.5 years ago. Had everything set the night before an early departure. Truck was attached to the trailer with the tongue jack down just enough to release the weight from the hitch. In the morning I simply raised the hitch and left. Little did I know that someone decided that pulling my pin would be a funny 'joke.' As I crested a small hill on the way out of the campground early the next morning, the stinger slid right out of the hitch and the tongue came crashing to the ground.
NOT a funny joke, but it was my bad for not checking things in the morning. Luckily the sound and the scare were much worse than the real damage. Chocked the tires, jacked up the tongue, reconnected, and moved on.
Never happened in 5 years of towing before that, and would likely never happen again. Still, I now double-check ever point of the connection after every stop!
