kwacko's avatar
kwacko
Trailer hitch
Hi new member question I have I have a 2017 palomino puma 31dbts travel trailer I want to install a trailer hitch on the rear of the trailer so I can move it in and out of tight space we have a seasonal site and can not get the truck back in the front with out moving other trailers out of the way thanks Keith Whaley
  • Don’t know what kind of terrain you have but years ago my father moved his around with a riding lawnmower. The ground was level and the driveway was concrete. He put a caster wheel under the tongue jack and a ball on the mower. Worked fine. His trailer was a bit smaller and not a whole lot of ground clearance but a 10hp motor maneuvered it around easily.
  • drsteve wrote:
    GrandpaKip wrote:
    How about using a tractor?
    What he said ^^^^^^
    At my seasonal site I have to hire a skid steer and operator to put my trailer into position or to remove the trailer.
    What he said ^^^^^^
  • Bobbo's avatar
    Bobbo
    Explorer III
    Can you turn the trailer around so the tongue faces out the other way?
  • The trailer would need to be balanced. A larger trailer with 800lb of tongue weight for example, would create 800lb of lifting force at the bumper if the axles were centered. Think of it as a prybar or lever. But the axles aren't centered, so you would need more than 800lbs pushing down on the rear of the trailer to hold the tongue in the air in this example.
    Placing a caster in the hitch or on the jack to support the tongue weight would be necessary in most cases so that you have enough axle weight on the truck to maneuver.
  • wnjj's avatar
    wnjj
    Explorer II
    I don't know how well that would work since trailers by design have the axles toward the back to create tongue weight.
    Even if you get a fabricator to build you a custom "rear tongue", hitching up would be tricky. You would have to raise the normal front jack to force the new coupler down onto the ball, latch it then retract the jack.
  • wnjj's avatar
    wnjj
    Explorer II
    bgum wrote:
    Install the hitch on the front of the truck.
    That will still leave the truck trapped in by the trailer, just facing the other way.
