coolmom42
Mar 06, 2015Explorer II
Unless your son lives way outside of any area with zoning, you are going to have regulations against a RV hooked onto his sewer & permanently in place. You will also need a shade structure and 30 amp/110V power supply. Those things are not free, including the RV that will be worth about zero in 10-15 years.
If your concern about sharing a home is independence & privacy, (legit concerns, for sure) take the money you would spend on the RV setup, and use it to modify or add on a house to suit your needs. It will be much less expensive in the long run, and in the end your son will be left with an asset, instead of a decrepit RV to dispose of, and hookups he has no use for. The upkeep and utilities will be much better for an apartment attached to a house, as well.
I'm only 59 but have had enough knee & hip issues already to know that living in a RV is not for the mobility limited. No way you could manage the entrance steps on a cane, walker, or crutches, and the small space of the bathroom, and narrow doorways, would be very difficult.
44,056 PostsLatest Activity: Nov 19, 2013
