rsaylor3
Feb 11, 2017Explorer
Thank you so much for the in depth explanation on this! I absolutely want to do the right thing when towing, I have my wife and little boys in the truck every time and I don't want to get it wrong.
I did replace the cheap tires that came on it last fall. It came with load range D, I went with the new Carlisle radial trail HD in load range E. Size st225/75/15. They are rated for 2,830 lbs each.
So I need to find a place to get it weighed at each tire and then go from there. Since the axle is rated for 4,400 I can at least be assured that each spring pack is rated for 2,200 then?
Thanks again for all your help. Any ideas for finding a place to weigh it Y each tire?
