SoundGuy
Jan 06, 2017Explorer
azdryheat wrote:
My point is the dry weight means absolutely nothing. You need to know the gross weight of the trailer, the GVWR, which is the only number that matters.
Of course dry weight matters and in many cases is a lot more relevant that GVWR when CCC is WAY more than any reasonable person would use. Add 1000 lbs to the trailer's UVW and for most that will at least put them in the ball park of what the trailer will typically average loaded and ready to camp.
To the OP - check out my gallery and you'll see my own custom version of a towing weight calculator I use for my own 2005 Avalanche. If it interests you PM with an email addy that accepts attachments and I'll send you a copy in .xls format you can then modify with your own numbers.
FWIW I've been towing for 10 yrs with a 2006 Silverado and our current 2005 Avalanche and wouldn't tow any more than 6000 lbs loaded & ready to camp. Less is always better though and our current Coachmen at ~ 4600 loaded is definitely an easier tow than our previous 5500 lb KZ Spree. Any thoughts you can tow much more than this will just be in your imagination. :W
44,071 PostsLatest Activity: Aug 30, 2026
