transamz9
Dec 13, 2016Explorer
wilber1 wrote:
Not sure about the 2500 number but the difference in the 3500's makes some sense. The truck's GCWR is probably limited by the manual transmission, so the heavier DRW will have a lower tow rating. Tow rating = GCWR - truck weight.
Actually it does make some of the difference. The biggest effect is the final gear ratio. Heat buildup is a big part. The other factor with the higher gear ratio is the ability take off in reverse on a grade and the reverse gear ratio makes a difference also the ability to hold in park on a grade.
44,072 PostsLatest Activity: Aug 23, 2026
