eend's avatar
eend
trailer made out of cardboard!!
The Other day I was in our rv and noticed a brown staple on the ceiling, then I noticed the ceiling on the top righ thand corner was all soft and bubbly. **** I have a leaky roof.
Today I removed the strip that runs across and holds down the front cap and the roof membrane as well as the strips that run from the top to the bottom on each side, then I peeled the font fiberglass cap back and I was surprised that there is not on chunk of wood underneath the cap , just cardboard no wonder these trailers are build so cheap.
So I left the cap lifted and let it all dry out, I then put a tarop over it all with a fan blowing under it so hope fully it will dry out soon.
I also noticed the sides are starting to delaminated and it was definitely wet.
I better have everything ready and buttoned by this weeks end as we are going a 14 day trip.
  • yes... there is "no cell structure" like cardboard, the "1/4" inch thick panel is "full fibered" BUT if it gets wet, it likely loses its physical form and at the very least, usually appears to lose the contact surface / glue such that the top fiberglass sheet pulls away from the substrate.
    I recently dealt with the issue on my Terry Dakota where the upper clearance light on the front top curve section leaked over time. It resulted in the seperation of the two layers. I "injected" in epoxy resin via the the side seam (taking off the metal corner bead) and also thru the clearance light cavity. Its not perfect but hopefully will hold although the integrity of the substrate is suspect as the glue interface surface is no long intact. Various videos on line provided the "guidance" or "directions". It was relatively easy to do a "triangular" shaped area about 1.5 feet at the top trailing down along the side for about 3 feet. I guess time will tell if I was successful. I am still considering what to do at the crest of the curve at the very top. The "substrate" there has dropped such that it doesn't support the curve shape. That is because at the top, behind the panel / filon is fiberglass insulation as opposed to foam and thus there is no solid sublayer (ie. the top panel was just curved / form around the cavity... the reason for the filon in the first place). I was thinking of injecting a bit of "low expansion foam" into the cavity but worry that it might not help since there isn't any solid "containment" in the area. I will likely leave well enough alone.
  • budwich wrote:
    I don't think its "cardboard". It is a form of "light density masonite" / "fiberboard".
    Yeah, like the back of Ikea type flat pack furniture.
  • I don't think its "cardboard". It is a form of "light density masonite" / "fiberboard".
  • Has anyone else found cardboard in any trailer ever?? I am sure the OP is telling the truth, but this sounds like a one-time foul-up, rather than a systematic practice.
  • Not all that surprising....It's part of the quest for (ultra-ultra light) and inexpensive trailers that can be pulled by the family van.
    Cardboard is substituted for marine grade ply.
  • I know the filon cap has a strip on each side that is screwed down. Is the filon also screwed or is it stapled below that. I am going to take mine off and build a wood and plywood base cap then glue my filon cap to that. Just want to know what to expect. Any pictures would be great.
  • It does say a bit for the old stick and tin (aluminium) construction, but it have see a lot of short cuts behind the access panels of my TT also.
