Bucky_Badger
May 12, 2013Explorer
MicahDD wrote:RoyB wrote:
You are looking for a coiled up SHORE POWER CABLE...
Roy Kenbob213 wrote:
You should have something like this that will allow you to plug in at a CG. With the adapter you can plug in at home.
shore power cord
Thanks guys. So in effect I need two adapters.... one that's the shore-power cord, which will adapt from 30amp to 15amp, then the regular 15amp to 110 adapter?
Why would they do it like this? If shore power is 15amp, why have a 30amp plug on the trailer that then requires an adapter cord to make it shore-power ready?
I don't know anything about shore power, I usually dry camp. But on this trip we'll be shore powered quite often so I need to figure this out in advance.
Your camper is 30 amps...if you have the proper shore cable, it will plug into most CG Receptacles. You should only need the adapter when plugging into 15 amp.
Have you found the shore cable pictured above? If not contact the previous owner.
44,056 PostsLatest Activity: May 04, 2014
