mordecai81
Dec 15, 2015Explorer
Campfire Time wrote:
Most don't. I don't. And you have to be careful. If you have Dexter torsion axles you can't jack them up or put blocks under the axle itself otherwise you'll damage it.
I park on a gravel pad and have 2 in boards under the tires so it doesn't sink in the spring when the ground is wet.
I understand about not jacking up under the axle tubes, but putting blocks under the frame must be o.k.. Or is their something I'm not getting about this?
44,068 PostsLatest Activity: Jun 10, 2026
