Huntindog
Sep 28, 2014Explorer
LarryJM wrote:rustymusket wrote:
Larry:
Thank you for your interesting and lengthy explanation of the issue and means of resolving it.
Please forgive my confusion, but my background is healthcare, specifically hospital pharmacy; I am not an engineer.
I am estimating the total weight of my 40ft coach to be in the range of 5-6 tons, with contents.
The screw-type jack stands do not appear to support any significant weight; would 1-ton screw-type jack stands distributed every ten feet on each side of the coach be sufficient to handle the coach weight, or do I buy larger capacity ratcheting stands? And what capacity stands?
What about the hydraulic jack--are we talking bottle jack and in what capacity?
Your perspective and rationale are both reasonable and cost-effective.
I thank you for your time and efforts.
Hank
Personally I would look at getting two sets (each set has 4 stands) of the Camco 44560 Olympian Aluminum Stack Jack Stand which go for around $34 at Amazon and each stand supports up to 6,000lbs more than enough.
Just for convenience I would get like a 6T bottle jack that would run you less than $20 again from Amazon.
So for less than $80 you would have all you would need.
Now if you wanted to go the Roll Royce route get the Camco 57371 Olympian Telescopic Jack ($36 each), but those aren't all aluminum and would require more maintenance than the Camco 44560 stands and I'm not sure how much more they are buying you.
As an experiement you might just invest in the bottle jack and see if by using it along with what you have now you can get enough support to satisify your needs.
Larry
WARNING!!!!
Those aluminum jacks will NOT support 6000#s each..
If they did, then a lot of mechanics have been duped... Look at jack stands for supporting automobiles when working on them.
I have a PAIR of stands that are rated for 3 tons (6000#) for the PAIR. They are noticeably heavier duty and made out of steel.
I have another PAIR of truck stands rated for 6 tons for the PAIR. Or 6000#s each. They wayyy heavier than the 3 ton ones.
One should say that the aluminum jacks can stabilize 6000#s.. Not support it.
Be safe out there.
