rustymusket
Sep 28, 2014Explorer
Huntindog:
I'm not clear where you got your information on the Camco aluminum stand capacities, but I verified the information on the Camco website where they also state these stands WILL support up to 6,000 lbs, or are you suggesting the four stands contained in the box will collectively, but not individually, support up to 6,000 lbs?
This number is of no consequence, as the coach is supported by six scissor jacks, the four tires, and a hitch stand, and I will be initially adding only two Camco stands just aft of the axles to see if LarryJM's suggestion works. Based on the previously-mentioned existing tires, jacks, and stands, each Camco stand will only be supporting approximately 1,000 lbs.
I will be ordering a total of eight Camco aluminum stands, and if my initial attempt to stabilize the coach with two Camco stands behind the axles fail, I will be retracting the six factory-mounted scissor jacks and using the other six Camco stands in their place, but spacing them ten feet apart on both sides of the coach, also as recommended by LarryJM.
I understand your concern, and if you have proof of your claim, I'd suggest you contact the manufacturer.
Otherwise, do you have an alternate suggestion to solve my RV problem?
