NanciL
Oct 27, 2016Explorer II
It is simple.
Prior to raising the tongue jack remove the pin that holds the hitch to the receiver.
Then when you raise the tongue jack, this allows the hitch to move a tad and relieves the holding pressure, and the coupling will raise right off the ball as you crank it up
I learned this method many years ago and use it every time I unhitch
Jack L
Jack L
