rbpru
Oct 27, 2016Explorer II
I have found that the ball is sticking on the lip of the socket, even when greased. I have three methods I use to release it.
1. Since the trailer should be chocked, I disconnect the WD hitch, release the ball latch and level the truck and trailer. I then bump the truck in reverse to free it up. This is a real pain since it often goes a bit too far and is now jammed against the back of the ball socket and release latch.
2. With the trailer chocked and the WD hitch connected, I release the ball latch and crank the ball up just a couple of inches. This is easy because I am not lifting it far and the bars are still pushing upwards. I release the bar tension and usually when the second bar is released the weight of the truck causes the ball to fall.
3. If step #2 does not work, then with the trailer chocked; I just jump on the hitch like everyone else.
You will note that the trailer is always chocked. If you have ever had your trailer slide a couple of inches before the crank post dug in, you will not forget a second time.
