dadechil
Oct 27, 2016Explorer
Dennis12 wrote:
Put a lot of black grease on the ball and then go put on your best pants that you own. Now walk past the ball and get the grease on your pants. WRONG. The ball requires NO grease. Manufactures will tell you that the grease on the ball will attract dirt and grit. You can use spray grease to lubricate the locking mechanism but none on the ball. If the ball is all of the way forward your locking mechanism should latch or unlatch with very little effort. If it dose not you may need to adjust the large nut under the mechanism. You will see the fork going under the ball so that it will not come up. Make it as snug as you can with out it not sliding off of the ball when you crank it up.
The number 1 name in towing sells this product . I will go with there recommendation and grease my ball.
Ball grease
