coach4life
Sep 28, 2014Explorer
Trailer Sway
I currently tow a 30ft - 2011 open range roamer 303BHS (7100 dry) with a 2013 f150 ecoboost (previously a f150 v8)and we loved the design & floor plan as it was different than all the others at the ti...
MitchF150 wrote:
You need to get some actual weights on your rig to tell a few things, but just guessing off the cuff, it sounds like you might not have enough tongue weight.
So, lots of things it can be, or maybe you are just ultra sensitive?? To me, "sway" is when you are see sawing the steering wheel to gain control over the rig... If all that's happening is you feel a wiggle or a tug or pull from the trailer when conditions warrant, that's just what's happening at that time and may or may not be 'normal', but is not a condition that should cause an out of control situation either..
