coach4life
Sep 28, 2014Explorer
Trailer Sway
I currently tow a 30ft - 2011 open range roamer 303BHS (7100 dry) with a 2013 f150 ecoboost (previously a f150 v8)and we loved the design & floor plan as it was different than all the others at the ti...
Wishin wrote:
Third, you need to evaluate your hitch set-up and if you have the right hitch. What kind of sway control do you have as part of your hitch? A good integrated sway control system will help significantly reduce the amount of push/pull you get from passing cars and trucks. This is a separate issue from the sway that happens by itself when you go faster...
