Gjac
Sep 24, 2019Explorer III
Trailer sway
Having followed a number of trailers I noticed a lot of swaying on some, and have heard that towing a 5th wheel eliminates that sway. I have been looking at short 5th wheels and trailers in the 20-25 ...
Gjac wrote:naturist wrote:The "open ended question" helped me understand the issue. A more specific question would be what if the hitch weight is correct, tire pressure correct and I pull a 22 ft trailer with an F150 truck what would be required to eliminate trailer sway (if anything)? Are there some short trailers that are more prone to this problem be design?
There are a lot of factors that influence sway, and there is a lot of information (and misinformation) available about it. Everything from weight of the trailer vs weight of the tow vehicle, to weight distribution between trailer tires and tongue weight, to tire pressures all around, to 5th wheel vs bumper pull, to length of trailer vs TV wheelbase, all affect sway or lack of sway.
You asked a very open-ended question, and you are going to get a LOT of responses. Some of them will even be right on, as far as they go. Good luck sorting through it all to the answers that make the most sense to you.
