jotityraExplorerAug 15, 2020Trailer swayCan trailer tires cause trailer sway? I have a 2015 jayco 26bh and I am sure the hitch is setup correctly, but I am getting more sway than I would like. When a semi or a truck pass by it really pulls ...Show More
valhalla360NavigatorAug 15, 2020Have you weighed the rig to see what the hitch weight is?Most common issue causing sway is too little hitch weight. If you are on "C" rated tires now, I would not move up to "G" rated. That's way too big of a jump. It would be like the trailer ridding on rocks.There will always be some sway when a semi passes. If it's more than you are comfortable with, I would check into a sway bar.PS: I'm not seeing the torsion bars on your picture. I assume you do use them when actually traveling?
Related ContentSway ControlTrailer sway issiestruck/trailer swayTrailer SwayTrailer sway milestone 377mb
