ktmrfs
Nov 15, 2018Explorer II
AFAIK tpms systems are not required on 1 ton and above vehicles so GM and looks like ford at least aren't installing them as a std feature. OEM sensors or a correct type aftermarket replacement snesor would likely be needed to pair correctly to the reciever if it is in the truck. If you want them I'd go to a ford dealership and find out if it is possible to make it work with your truck
44,025 PostsLatest Activity: Feb 26, 2025
