Travlingman
Nov 17, 2018Explorer II
ktmrfs wrote:
AFAIK tpms systems are not required on 1 ton and above vehicles so GM and looks like ford at least aren't installing them as a std feature. OEM sensors or a correct type aftermarket replacement snesor would likely be needed to pair correctly to the reciever if it is in the truck. If you want them I'd go to a ford dealership and find out if it is possible to make it work with your truck
The tire sensors were standard on my F-350 dually.
The op is talking about the option where you can install them on your trailer and they show up on your dash along with your truck tire sensors. As stated above, buy from dealer and install in tire.
44,025 PostsLatest Activity: Feb 26, 2025
